Im going this swap over the weekend (i hope) in my '80
CJ5 . The PO did the YJ spring conversion bud did not change the front hangers for some reason. All he did was get the 2.5in shackles (i think) and add 2 washers on each side of the top mount. Im assuming the spring perches (on the inside?) and the spring plates were replaced, not sure how the springs would fit otherwise.
Needless to say, it drives like
over 35mph. Serious wandering and death issues. So dont cheap out and try to skip.
I ordered a set from quadratec (
Mountain Off-Road 7686FSH25Y - M.O.R.E. Front Shackle Hangers for 76-86 Jeep CJ with 2.5" Wide Springs & 1-1/4" Diameter Bushings - Quadratec) that say bolt on (and ill spot weld to be safe) and also this shackle set (
Original Replacement Parts 2040415KHD - Heavy Duty Rear Greasable Shackles for 76-86 Jeep® CJ Rear & 87-95 Wrangler YJ Front or Rear - Quadratec) for the bolts, bushings and spacers. The PO put what look like currie tow shackles on it so ill keep them.
Anyone have advice on the install?
best way to jack and support the frame and axle so the thing isnt under pressure?
Steering box issues? (CJ has an updraded steering box but it looks like its sharing a bolt with the shackle mount).
Otherwise, there is an awesome thread with a build list and part links for an OME lift kit. i think total parts came to $1100. I would search for that as there is a TON of detail in the thread. Ill post pics if i get to this over the long weekend. I also need to strip and repaint so we will see how long that takes.
