CJ7 axle shift.
CJ7 axle shift.
Cduke88
Poth, tx
1984 cj7
Hello all. My 1984 CJ7 which is bone stock just got new tires and rims. When I had all 4 off I was trying to get the slop out of my steering and upon checking it I found that when I turn the wheel all the way to the right it turns so far the the axle shifts about an inch. Best I can figure is the that is all the turn I have but the gear box has more to go. What is the best way to take that out of the steering? Thanks in advance. b8775068dec103079fe717427ab77322.jpg
Sent from my SM-N950U using Tapatalk
Check the limit bolts on the inboard side of both front brakes.
Ok so I adjusted the driver side limit bolt and took out the axle slide. So now I turn a inch farther to the right than the left. Is that going to hurt anything? If not I can deal with it
Set the limit bolts, so the tires clear the springs about 1"
This ^ and I will add check your torque on the spring pad u-bolts, should be 70-80 ft-lbs. The axle shouldn't shift unless you mean it's pushing the entire front suspension. In that case the tire is probably pushing against the frame.
What was happening is when I turn the wheel to the right it hit the limit bolt and there was still movement in the wheel. I could turn the wheel until the steering box would stop. It would push the whole suspension over about a inch. I adjusted the limit bolt and too care of that allowing the right turn to go farther. Now there is about a inch measured distance farther turn right than left.
What's your source for those specs? :confused:
As per FSM, MR-252, page G-140......
9/16-18 dia is 85-105 ft/lbs.
1/2-20 dia is 45-65 ft/lbs.
Not sure I understand-:eek:
Can you post a picture or two?
Well that is fixed. The limit bolts helped. Now I have a ton of slob in the steering wheel. All ball joints and steering shaft is tight. I tightened the adjustment bolt on the box but am scared to do it too much. Any other advice?
BDS suspension install - u-bolts 75-85 ft lbs
Haynes CJ manual - u-bolts 70-80 ft lbs
Don't own a fsm yet.
Since I have BDS suspension, I chose the Haynes torque values not knowing OPs suspension. However if the fsm shows a lower value I will defer.
Check your steering shaft the bell connector could be worn.
Errors in torque settings--
That alone should be the reason to own a true FSM.
I've seen to many mistakes in those 'general' manuals to ever trust'em.
To true!
I do trust BDS torque settings since it's their kit.
:agree:
If that ck's out OK-
Check out the upper & lower ball joints in the knuckles.
To true!
I am currently installing a BDS kit and came across the same variances. LG's numbers are from the original OEM u-bolt specs. And the BDS torque specs are likely higher due to a better steel grade than what Jeep used 35 years ago.
Grade 8 bolts will take a higher clamping force (i,e. more torque) than say a grade 5 bolt, although both might suffice for the same application...
I torqued mine to the BDS value.
