CJ7 clutch pedal replacement ?
Are you sure it's the bushing?
The balljoint connected to the pedal can squeak.
Did you pull the Pedal off the shaft to grease it?
The bushing will be shot if the pedal moves side to side a lot.
Is the rod rubbing the body where it goes through the floor ?
