CJ7 Spring shackles
CJ7 Spring shackles
Captainlance
Long Island, NY
1984 CJ7
I'm in process of rebuilding a CJ7 that 2 prior owners cobbled together. My question: it has new, aftermarket shackles on the springs, it is obviously lifted up, what is the distance from bolt to bolt on a STANDARD OEM shackle with no lift?
Lance
3 inches outside of bolt to outside of bolt.
Mine were so badly rusted, you're probably right.
My originals weren't rusty like the ones shown. Mine were bent and warn about 1/2 way through the bolt. Replacing them made a big difference in the ride quality.
Outside to inside measurement is a fairly common way to measure between centers. Much easier than trying to figure out where the center of a hole is. Just remember to measure to the same point on two holes I.E. Outside to inside or inside to outside. Or inside to inside + 1 hole diameter. I've used all of these methods from time to time, even when I part of a land surveying crew when centers were hard to find, manholes for instance.
Exactly like that!
