cj7 steering stabilizer HELP!!
Dan86CJ7
Mass
1986 cj7 258(rebuilt motor/comp cam/weber32/36) T5 300 tcase d30 front(locker/4:10s)
AMC20(locker/4:10s),4"lift,33"s
when i picked up my CJ7 the guy had replaced a tie rod and at that time removed an add on steering stabilizer....i will tell you no matter how i have it set up it hits diff cover,doesnt seem to fit right :censored:...can anyone please!! post some pics of how your is mounted...tks
I have the same issue.Tried several different ways. It had to have been hittting with the po. What brand did you get?
I cann't fine a pic of mine as I don't run one anymore, but it mounted to the driverside spring pad and the tie rod so it didn't come anywhere close to the diff. cover as I remember.:confused:
it came with the jeep, its a rancho, mine didnt have an oem stabilizer..PO said he took it off when doing a tie rod and never reinstalled..figured id try to put it on if i had it sitting around.
I'm not sure if the one on mine was stock or not, but with the mount bolted between the spring and the axle I figured it was.
:confused:Here is some pics of my oem set up.It will bottom either left or right no matter what I do.
