Clutch Issues - HELP!!
BaseCJ86
Ok guys I got another good one. So I have an issue with a timing change that may have skipped a tooth. While taking apart the front end, I went to take the bolt off the balancer and while attempting to turn the bolt, the crank turned. I know I am just a shade tree mechanic but I know that is not suppose to happen. The Transmission and Transfer Case is in gear. I went under and checked the linkage, I pulled the fork boot and there is a lot of slop, the fork can move up and down (I am sure the internal spring has come off the fork), but I can see the ball is in place. I had my son push the clutch pedal, the fork moves back and forth and I can see the bearing move. I had my son roll the crank and I can see the clutch housing turn, so nothing is broke. I drove the thing into my garage 2 years ago for a before I did a body swap. Can a clutch plate in not engaging, is it stuck open?? I have heard of clutch 's freezing to the clutch plate, but not open. Any insite will help. I want to get this baby back on the road this spring.
