clutch issues
1986cj7
- Media
- 13
- southeast missouri
- 1986 cj7 258, t-176 4-speed, d-300, moser one piece axle in back in amc 20,G2 4.10 gears front and back, detroit truetac front and back,G2 4340 chromoly front axles in a d-30, 4" rough country lift, 33" tires
My clutch now when pushed in makes a clattering and grinding noise. It has shuttered for a while when taking off. When I had the 2.73 gears in but went away when 4.10 gears where put in. Thought is was just to high geared. But it started shuttering a little and now when the clutch is depressed there is a clatter and grinding. I've tried adjusting the clutch but hasn't helped. Now If you put the clutch in and try to shift into first or any forward gear it will not go into gear or grind. Only if tring to put in rev. it does grind. Does this sound like a bad clutch and pressure plate and or throw out bearing. Just wanted some advice before tearing apart. I hope it is a clutch issue and not a Transmission issue. I just replaced the Transmission lub with gl-4 had gl-5 in it for awhile and found out was wroung fluid. Hope running the wroung fluid didn't screw the syncros. up. Any thought or advice will be aperciated!
