clutch mount
clutch mount
scooby
van lear ,ky.
77 cj5 304
help I am starting a build on a 77 CJ5 it has had the frame blasted and painted and all mounting brakets removed and didnt come with it and i can not figure out were to mount the clutch braket not even sure what the mount looks like
Part 7 goes from the clutch pedal to the linkage part #1.
Part 1 is held in place with Part 14 (mounted on the inner firewall).
Part 1 is also held in place with Part 5 (mounted to the bellhousing).
As part 1 rotates it pushes on part 2 and 4. That is what pushes the clutch fork (part 3).
I am guessing the main issue is mounting parts 14 and 5 so part 1 can rotate.
I hope this helps.
