Clutch return spring question
jakeh937
- Petaluma, CA
- '79 Cj5, 258 with Howell Fuel injection kit, T18 with dana 20 Tcase, dana 30 front with Detroit locker, AMC 20 rear with LSD and one piece shafts, Warn 8k winch, 1" body lift, 2" suspension lift, 33 tires
Finally, after some hours of sketchiness, I managed to install the clutch return spring. However, when I push the clutch, the spring cocks to the side and rubs along the end of the clutch bearing. Is this normal or is something wrong?
