Clutch Stops Working - What Now?
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
Getting Your Jeep In GearSo you are out in your Jeep and you are set to go. The engine is running and you press the clutch to put ’er in First gear, but all you get is grinding. Try as you may, you can’t get your Jeep into gear no matter how many times you pump the clutch. The truth is that this almost never happens without some forewarning—a slipping clutch as you drive down the road, spongy clutch pedal, or maybe some grinding while shifting. Either way, something is now very wrong with your clutch. The truth is that it can be caused by major clutch component failure, but it could be something simpler than that. What do you do? Well, this time in “What Now?” we will talk about a few things to check, a few things to try, and if those don’t improve things, we have a few tricks that might, just might, get you home.
Photo Gallery: Clutch Stops Working - What Now? - Jp Magazine
Clutch Stops Working - What Now? | Digg It | Add to del.icio.us
More...
