column cj5
column cj5
Banana745
northeast
Hey guys and gals,
I know this has been discussed before im sure.....what Tilt steering column is best to use for CJ5 in the 1974 era...
Thanks for input :chug:
I have heard of people using the Cherokee column. You want a older one with out the airbag.
MtnWhlr is the cherokee column a bolt in? What will you have to adjust to make it work.
I myself have never done it but I have seen a few in CJs so it can't be that big of a deal. If I was to do it I would get one and then pull my old one and lay them next to each other and modify it to bolt in.
Not sure any tilt column is a bolt in for a 70's vintage CJ. I had to build/modify the brackets to make a GM column fit in my 75. It took a little time, but it wasn't too big of deal.
before 76 did not use the GM column. 76 and later are pretty easy, but that does you no good, sorry.
$45.00
  22.5%
