Compression ?
Been a while but if I remember correctly a healthy engine will read over 100 PSI with no more that 10% variation between highest and lowest reading.
Make sure the throttle is 100% open when you test.
IIRC it should run 120-150psi.
Why do you feel the need to make this test?
