Control Problem
JeffP
- Media
- 27
- Peoria, AZ
- '75 CJ5, 304, T18, D20, D44s w/3.73 1974 CJ5, 304, 4 spd., Dana axles 3.73 gears. 1973 CJ5, 258 I6, T18, Dana 20, Dana axles 4.27 gears. 1972 CJ5, 304, 4 Spd, Dana 20, 4.27 gears. 1976 CJ5, 304, T150. 1976 CJ5, 304, T150, J20 w/4.10 gears. 69 CJ5 Hurricane 4 cyl, 4spd all original! ‘53/‘54 M38a1 100% original but also 100% apart! Low 3 digit Vin! One of the very first m38a1s!
I need some help on this one.
1975 CJ5 , AMC 304 , T-18 , Dana 20 , Dana axles, manual steering, manual brakes.
When I put this Jeep back together, we stripped it down to the frame but left it standing on it’s own suspension.(for portability) The springs, bushings, shackles etc. all looked good so they weren’t disturbed.
The gear ratio was changed fro 4.27 to 3.37. Front hubs rebuilt, new tie rod ends, new steering box, new shocks, (steering shock added also) new brakes, new tires etc.
I got the alignment almost dead on, but took it to “the master” for a professional alignment. He looked it over, tweaked it a little and gave his blessing. (Absolutely no question about the alignment guy or his work!)
So... here’s the problem... If I’m going straight & let go of the wheel, it continues straight as long as I don’t exceed 40 mph. Barely over 40, I don’t dare take either hand off the wheel! I’m fighting for control! It’s not a wobble, more like the feeling of an overloaded trailer that is fishtailing.
Don’t tell me “it’s a Jeep... they do that”.
The only component that isn’t new or rebuilt is the springs & bushings, but again they “looked” great, possibly recently replaced before I got it.
The only test I could come up with was to crank the steering wheel while watching the front end. Nothing loose, springs aren’t moving... again everything “looks” good. WTH?
Any idea what the problem is? Could springs, bushings or even mounts / shackles cause the problem?
I’m not being overly picky, it’s really bad! To the point I don’t dare let someone else drive it!
