Corner guards
Corner guards
jeep cj7 304
Colorado Springs
They look great and damn heavy duty too! Just make sure you prime well under em and you should be good for a long time!
You in Colorado right? Aren't you supposed to be under a bunch of white stuff with the rest of the norther Jeepers? :D
One question? I have never had a square tail light in my hand. Is the base on them round? Do you have to modify the lights or the guards?
i'm actually changing them to circular led's so that is why the guards are like that, so i'll just be cutting a good size hole in my body. but the original lights are just boxes with 3 bolts coming out the back to hook it to the body. We arent like the north, it snows 6 inches and then dissapears 2 days later. It scares me sometimes.
We will need pics and links on that! LED's should work great, impervious to water. Are you making them custom or are they off the shelf?
Excellent find (nice Jeep)! Those look great and they are inexpensive also - definitely bookmarked. Have an idea on what you are doing for bezels?
I wonder if they make clear / white ones. They could be good backup lamps or turn signals for the front.
I wouldn't powder coat. Powder coating has trouble sticking to sharp corners and edges. When it flakes off you can't paint over it. If you paint it with a good quality paint you can refresh it by touching it up.
Powder coating isa very good idea. Once it's done you'll never have to worry about it again. Big $ but a no-brainer.
I got a quote a couple days ago for about $160, so it takes a good amount of cash.
I guess you have a point, I might talk to the guy about that and see what he has to say. if not it looks like I may be breakin out the spray paint once more!!!:poke:
alright i got pics:D
First time i tried mounting them the fasteners were so cheap that the lock washers locked down and i ended up breaking a couple of them. but they just needed a good coat of oil and panther piss. they ended up fitting decently since my body is slightly torqued and i found out that the guy i bought it from has no body work skills as their was 3/4ths of an inch of bondo in some spots. here's an album with all the pictures. just ask if you want more.
corner guards pictures by jeep_cj7_304 - Photobucket
Looks great and like your almost there! The rear light looks great.
I'm impressed that I saw you wearing hearing protection in one of the pictures! Um, you for got the safety goggles though :D
So are you done or are you still working on them?
im not quite done, the corners are still bare metal, so that was just a test fit.
i have a loud compressor, thus is why there was hearing on. but who needs eyes anyway.:D
Looks good. What color are you getting them coated. I am getting ready to do an article on coating my crossmember with por-15. You could use it and topcoat them with another color. Would make touch up easy if ever necessary.
Like it , thanx for the pics. ( Your not fooling anyone , Mountain Dew doesnt come in a brown bottle ) :D
Hey man - welcome back!! :chug:
That CJ is looking better and better! I like the wrinkle finish!
$100.00
  50.0%
