Correcting drive shaft angle
Flex BT
- Chesterfield, VA
- 1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains
Blue and rust colored.
My jeep has a pretty significant lift. The drive shaft angle is messed up according to everything I've read. Shims have been put in place to point the rear diff. straight at the transfer case, which is almost flat. To remedy this, is it as easy as just removing the U bolts on each side, taking the shims out and replacing everything? Is it possible to do this without replacing the U-bolts or should I have them in hand already before I start the work? I'm wondering how it will sit with the shims removed or if I will have to reverse them to get it close to correct. Damn POs.
From behind the driver's side tire:
