D-44 axle swap
D-44 axle swap
IOPort51
Garland Texas
1977 cj-5
2006 Toyota Tacoma
I am replacing the AMC20 in my 1977 CJ5 with a Dana 44 from a 75 CJ5 .
Do the spring perches have to move??
Just because I broke my 20 doesn't mean you have to change yours.:laugh:
this has been "in the works" for a pretty good while. I am going to build the "mother of all CJ axles". A Dana 44 with OX locker and disk brakes.:D
I can make you a deal on a gently used AMC20 open carrier with 3.54 ratio.:chug:
:drool: I think the perches are they same but I'd take a tape measure to be sure.
With your housing and my locker and 4:10 gears someone could have a good rear.:D
Just heard from my brother, He measured the 44 and can you believe that the spring center is 3/4 inch wider than the 77? that means cut them off and weld the replacements 3/8" outboard. Ain't that a kick in the head!:mad:
With this in mind I think I shall order one of these kits:D
Dana 44 Rear Axle Simple Swap Kit - RuffStuff Specialties
I am a bit curious how they are mounting the shocks with these mounts or maybe these are intended for the SOA mounting.:cool:
that is odd that they left them squared off instead if having a rad. for the axle tube cut in.
are you looking at the same picture I am??:confused:
