D20 twinstick pops out of gear
73CJ
Crazy Sr. Respected Jeeper
Detroit Lakes, MN
73 CJ5 4.0 head on a 258, HEI, Holley Projection w/ 4.56, Detroit lockers Narrowed D44 front and full float D44 rear T14 w/ D20 4 wheel discs, 38.5 Boggers
I just put a twinstick on a Dana 20 Transfer Case . The rear axle pops out of gear under load. I put new detent springs in when I removed the 'pill'.
Anyone have any ideas?
What twinstick did you put on? I just purchased this one -->> Dana 20 Twin-Stick Kit but got it from Novak.
One of the reasons I purchased this tick is because of this statement. -->>
Provides a solidly-detented 2WD-LO position that WILL stay in gear
They have allot of trouble shooting information concerning jumping out of gear in a PDF. I attached it for you.
Thanks for the site. I suspect it maybe wear on the detent groove. You can hold it in gear, but really gets hard under load.
So that is the same twin you purchased? Did you have any trouble keeping it in gear before?
No it didn't pop out before. When I pulled the pill out I noticed the notches on the shafts were grooved from wear by the detent balls. Heavier detent springs or maybe tap a setscrew to crank up the spring pre-load?
Either one is worth a shot. I'd probably try a different spring first.
