Dana 18 Parking Brake questions
dauntless89
- Spokane, WA
- 1969 CJ5. 225 V6, T86, D18, D44 R & D27 F, 4.88:1
Alright, so I'm getting geared up for a serious overhaul after this four-wheeling season ends and one of the things I plan to address is the marginally-functional parking brake.
I have the stock D18 drum parking brake, with a newer cable. , I've taken it all apart and rebuilt it, I've tried adjusting it a half-dozen different times, and no matter what or how I do it it won't hold the adjustment. It'll work "better" (not ideally) for about a hundred miles or so and then go back to normal. Normal means I can usually trust it to hold the rig on pretty much flat terrain, if I pull the lever out as hard as i possibly can. When I go to re-adjust it, it is either too tight and drags, or it's too loose and doesn't work worth a damn. Huge PITA. It's not oil-soaked, the rear shaft seal isn't seeping and the shoes are new.
I've read about disc-brake conversions. I've read about a swap to rear drums that have the parking brake hardware in them. With everything else I'm doing, I'm not terribly inclined to add either of these to the list. I've read about various line-lock mods. I'd prefer to keep it mechanical and isolated from the brake hydraulics. York on-board air is on the list, and I'm toying with the idea of hooking up a pneumatic cylinder to the actuator lever, controlled by a toggle valve and regulator. If the dust seal in the cylinder can hold up to the under-Jeep elements, it should work pretty damn well. And if not, I'm out no more than $30 for an air cylinder and my time hooking it up. The intended use here is short-term stops with the engine running (constant supply of air pressure).
Doing research, I read someone claiming:
Can anyone substantiate this?
At this point, I'm extremely skeptical. D18s have a reputation for being leaky, but is that the brake's fault for sure? If the brake works so unevenly as to push the output shaft out of concentricity with the seal, to the point of causing it to seep or wear prematurely, I would say a bad seal is the least of your problems. But that was just my first thought and there could be something completely different going on.
Bear in mind I have no idea what this guy's professional experience may or may not be. It's also the only thing that pops up when I Google search the subject. And of course I don't want to spend resources on anything more than futile efforts to re-adjust it, until I can either blow the claim off as bunk or acknowledge it as a documented truth.
Any thoughts? Thanks fellas.
...any regular use of the system as a parking brake generally causes the rear output seal to seep oil...
