Dana 20 & T150
I too have a leak at the rear output shaft on the Dana 20 . When I pulled the fill plug it was over full. Being that the rear of the Transfer Case is lower than the tranny is this normal and will it equalize between the 2?. I am replacing the rear seal and flange gasket but should I go further and check the gasket between the tranny and Transfer Case ?
