Death wobble bs bump steer
1981cj7
Can anyone explain to me the difference between death wobble and bump steer? Or are they the same thing?
Thank you. I appreciate your response. I believe that I had both. I installed a new steering shaft and upper bearing, gear box(which had at least an inch of ply!), tie rod and control arms, and steering dampener. I also installed a new BDS 2.5” leaf spring lift kit with the front YJ conversion to 2” springs, and Currie shackles. Then got an alignment at the local tire shop. I’m running on 31” tires. The Death Wobble is gone. On a smooth road, it drives great even at 55mph. As soon as I hit a pot hole, all bets are off! It doesn’t jump nearly as much as it did, but it still sends the Jeep on a different trajectory. Recovery is a b*tch. That’s what makes scares the out of me. What to me seems like not much movement in the steering wheel, makes me feel like I’m going to flip. It sways back and forth a bit until I can stabilize it, which can take up to 5 to 10 seconds sometimes. Does anyone have any thoughts on how I can address this?
You mentioned tie rod...did you do anything with the drag link/pitman arm? Any significant angle at all to it is a major bumpsteer contributor. Ideally you want it as flat as you can get it (parallel to the ground). At 2.5" of lift it shouldn't be extreme, but I'd start there.
I had so little clearance between tierods and underside mechinery that I did a tierod flip, boring parallel holes for tapered inserts.
That sounds very useful. Did you need any special tools for that? Any videos on YouTube for it...etc?
