degree shims
dalefan88
Crazy Sr. Respected Jeeper
well i did what you guys said and pulled the degree shims out of the front axle. made the centering back alot better. i left the rear ones in.
Why did you pull them? You need 3 to 4 degrees positive caster to make the steering work best, do you know what your caster angle is?
