    Thank you for your support!
Dimensions between rear seat bolts
ColeTrickle
Fort Worth
'83 CJ7 Laredo 258/T5/D300
'80 J10 Honcho 360/727/NP208,
'79 J10 Honcho 360/TH400/QT,
'75 J20 "Workhorse" 360/T18/D20
I'm replacing the rear cargo floor area in my CJ7 . It didn't come with a rear seat but I plan to get a used one soon or in the future. The previous owner cut the floor out and didn't leave any trace of where the front bolts are supposed to go for the rear seat. They left the holes for the rear bolts for I'm assuming the back seat bolts and seat belts.
Can anyone give me the dimensions front to back and from side to side for the 2 front bolts for the rear seat?
TIA!
2 1/4" up from the seam to center of bolt and 5 15/16" from wheel well to center of bolt
Thank you mtnwheeler!
