Disc brake proportioning valve?
rocmoc
- 1970 CJ5, V6, 3spd, power steering, headers, electric fans, upgraded larger radiator, '78 grill, disc brakes (front only), swing pedals, hyd clutch, extended front shock mounts, upgraded front driveline w larger u-joints, warn OD, D30 front diff, lockers, 2100 carb, working on a '74 tub replacement, '78 windshield frame with '78+ Acme hardtop
I am completing a front drum to disc brake conversion on my '69 CJ5 . I am installing a '78 CJ7 Dana 30 with the factory disc brakes. I have the '78 disc brake proportioning valve & lines. Should I replace the stock drum valve with the disc valve or does is matter in this setup?
Thanks,
rocmoc n AZ/Mexico
Thanks,
rocmoc n AZ/Mexico
