Disk brakes vs Power Booster conversion
baddiesel
Beaufort, NC
1977 CJ7 304 V8 3 spd, D20TC, D30, AMC20, fiberglass tub, Edelbrock performer intake, terrible Carter AFB carb.
2010 Toyota Tundra 5.7, SR5, TRD, reg cab, short bed, stock.
Which would be a more noticable improvement. I've got a manual brake master cylinder and "all drum" brakes. I know if I installed both a power booster w/mc conversion and front disk brakes, it would a great improvement. I can't afford both at the same time, so I'd like a little advice from the "experts". Thanks-in-advance.:D
IMHO I wouldn't run disc's without having a power boster, so I say power first and than the disc's later.
x100....... also take a look at the YJ and XJ boosters they are better than the CJ boosters :chug:
I'll buck the trend my CJ5 had factory disk brakes and manual brakes and it stopped as good as power breaks. I think disc stops better than drum weather the are power or not. IMO
Mtn,
:)I would agree........CJ5 30-33 inch tires they stop just fine. No surprises!
:D:D:D:D
Yup I used to stall alot. I like manual with discs. Discs are way better when wet. Then put discs on the rear. You will say "Why did I wait so long".
Thanks for all the responses. I've looked at the power booster at Morris Off Road, and the Vanco version. Since I haven't had the chance to remove the stock MC, I don't know for sure if the bore is 1" or 1 1/8". Apparently, that makes a difference with the Morris one. Vanco, although more expensive, doesn't mention the bore size. I will follow up with front disk brakes next. I'm not too keen on mixing/adapting the us measurement scheme to metric (it is much cheaper to execute this mod).
Here is another place to check.
HTML:
Brakes
Thanks "Purple77CJ7", that's alot cheaper!. The booster will be my next mod, then the front disk brakes & new proportioning valve, then.......
