Distributor Gear / Cam Gear Reality Check
007
Crazy Sr. Respected Jeeper
- Media
- 5
- Solutions
- 1
- Reno, NV
- 1977 CJ-7 Renegade (Daisy Jane), Levis trim, 304, TH400, BW1339 (MM), D30/Auburn Max, AMC20/Detroit/G2's, 4.88's, 33" BFG MT KM2's, Edelbrock Performer intake, Holley Sniper 4bbl EFI, MSD6, MSD ProBillet distributor, OME shocks, 4" ProComp lift.
So we've all read and heard about distributor gear / cam gear horror stories etc. There's so much information it's overload.
That said, I have my Prestolite distributor "somewhere, I think", but in 2014 when I did my TeamRush upgrade, I put in a Motorcraft. I went to NAPA and asked for a distributor for a 79 CJ7 with a AMC 304 , and put that one in. During my upgrades this spring I removed it to lock it out for timing control, the gear was in excellent condition, but that said it probably has 500 or so hrs on it.
Anyway, as a part of this Sniper EFI install, you really need to phase in your distributor to make it idle right and to make the timing control accurate/efficient and phasing in a Motorcraft distributor like this seems to be a bit of a joke. I've not found an adjustable rotor that will pop on a Motorcraft distributor. SO, I got an MSD Pro Billet that will accept the MSD adjustable rotor. To lock this unit out, you simply remove the weights and springs, remove the gear, rotate shaft 180deg, drop the bolt and tighten it down, then reinstall the gear.
This leads to my question...is the MSD gear fine/made correctly/not too hard to run with my stock cam gear OR should I move the one from the Motorcraft that looks good with little use OR should I dig through the storage unit and find my Prestolite...assuming I still have it?
Any advice? Anyone using this distributor?
Thanks in advance...
