Distributor gear
Distributor gear
smbundy13
Texas
1980 CJ7, 258 I6, SR4, D300. Power steering, power brakes. Stock axles stock susp. Gentle rehab in progress.
Changing from normal 1980 distributor to a dui hei unit and everything i have read told em to change the original drive gear from the distributor to the new distributor. Well, when trying to do that, noticed the original gear’s inside diameter is a little too big. It isn’t a snug fit.
What do y’all suggest?
I have seen where people suggest buying a msd gear.
Any ideas?
There is a history of some of the aftermarket HEI distributors that were made in China had a gear that was harder than the cam gear it meshed with. This would cause the cam gear to wear out. At least that's what I have heard. I would think that a distributor gear with a DUI name on it would be made to the correct hardness. You could call them on this just to make sure.
Thanks for the info. I will call dui today and ask.
