Does anybody know where to get Mocha Brown Metallic
GoldenEagle36
SW Pennsylvania
1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
Does anybody know where i could get mocha brown metallic or do i have to get it mixed locally
If you are trying to match original? then the paint shop uses the color code on your build tag to mix the color.
Sasquach is right. They don't have pre-mixed colors. Sometimes it could take up to 15 different colors of toner to mix the color you're looking for. The paint shop will use the paint code to mix it for you.
Thanks for the advice guys:notworthy:
