Does GVWR determine rear drum brake size?
jlmnjem
Rudy
1978 CJ7
I'm trying to solve a brake pedal height issue (it sits too high) and I suspect the master cylinder push rod is too long. I think replacing the master cylinder with one that is supplied with a shorter push rod will solve the problem, but MC selection is based on rear drum size. The options are 10"x1-1/2" or 11"x2". I've measured my rear drum and it appears to be the larger drum, but what determined which size drum was installed. I suspect it's GVWR, as my VIN decodes to 4150 GVWR, but I'd like to hear from someone who knows for sure.
