Drag Link Install
jafo
Old Time Jeeper
Ok. Nearing the end of the 4" lift kit install. I ordered the Rugged Ridge HD drag link and tie rod kit. I have ran into a small issue. I got the drag link joint on the drivers side installed. I went to the passenger side and the joint on that end doesn't want to line up with the hole because the drag link diameter won't let me drop the bar low enough to line it up. It's making contact with the top of the leaf springs. I can see only two options. One is to loosen the leaf spring u-bolts to give me enough clearance, or is it possible to mount the drag link from the top instead of the bottom? It looks like the clearance will be really close even after it's tightened down. Anyone run this kit on their jeep?
