drivetrain bind in 4wd
Troy35
- Wilton, Ca
- '74 CJ5 with 304, T18, D20, stock axles with 4.56's, detroit in rear, lock rite up front. On board air, warn winch, rolling on 33's. A little rough around the edges.
So I took the '74 CJ5 up to the Rubicon this weekend and hit the trail. Overall, the Jeep did really well even though it's on 33's with little to no lift. I was stuffing my wheels in the fenderwells all weekend. But I had a significant problem that reared its ugly head a few times:
When on an obstacle (read rock) and fighting to get off of it, my tranny and tcase would lock up on me. I could not get my T-18 out of gear most of the time and when I did it would not go into gear with the engine on, it just would grind like I was failing to push the clutch petal. I tried pulling the tcase into N to see if that would free up the tranny but that would not move either. I ended up having to hold the key on and use the starter with the jeep in gear to move. Once on level or off the obstacle it would change gears without issue.
My friend told me that his '70 displayed this behavior a few times too. Honestly, it was my fault for choosing poor lines. When I picked a good line and used good throttle control I got over every obstacle I tried to tackle. But surely, something has to be going on with my drivetrain right?
If it matters it has a truetrak in the rear and a lockrite in the front. Stock gears and axles. A T-18 and Dana 20 . Like I said I don't think it has any lift but it might have some...those 33's are stuffed in the wheel wells.
