drum brakes
They MAY be broken off. It happens, really quite a lot.
If they ARE broken off, don't even think about it - just replace the cylinders. They're cheaper than the agony of trying to get broken bleeders out, and if the bleeders are broken off the cylinders will want a rebuild anyway.
yeah i started to remove the tires to investigate the drums and such but cant get the nuts off one. i think they are tack welded. this tire has a lot of play in it. dont know if i should continue or not. should i swap axles. is that something a novice can accomplish.
If you can't feel a definite weld, they're just stubborn. A long breaker bar, with a long pipe stuck over the handle, WILL GET THOSE NUTS OFF. You may possibly break a socket in the process - that's the price of life. If you break a socket, replace it and at the same time pick up an impact socket. YOU WILL GET THOSE NUTS OFF.
Time & again I've jumped up & down on a long breaker bar to get lug nuts off. HAD to, I only weigh about one-fifty.
It helps to roll the wheel so the lug nut is on the RIGHT of the hub. Put the socket on the nut and arrange the breaker bar so it CROSSES the centerline of the hub. You can get a lot better torque on it that way, with the least tendency to turn the wheel.
