Electric Choke question
mriplaybass
Full Time Jeeper
I have just installed an electric choke on a MC2100. Haven't tried to start the engine yet, but I did set up the choke. The choke opened nicely when I put power to it, but it just seems to get unnecessarily hot after being on for a while. I called the shop that I purchased it from to make sure it was designed to run on full 12 volts, and he said he was "pretty sure" that was the case. No instructions came with the unit. The wire going to the choke does not get hot. It has been too many years since I used an electric choke, so I don't remember what voltage they are designed to run on. I am sure there are electric choke users out there. What voltage are you running? Do I need to install a resistor?
