Electric fan
drivert51
Thinking about putting an electric radiator fan on, to save a little room. Anyone know the pros/cons?
I have a Flex-a-lite dual fans made for a cj comes with control temp unit manual switch .. Dont have to worry about fan going into radiator or a hose while on the trail wheelingI am pro electric fan. they are quieter, require less power, operating temp sooner, not running if not needed.
cons: need a control circuit with thermostatic switch and high amp relay.
Look here -->> CJ/YJ Electric Fans - Contour -JEEPTALK.netIf a person was to try a junk yard swap what would be a good donor car? I tried a 98 ford Taurus because I have a few kicking around but they won't fit between the water pump and the radiator on my 304.
