Electrical Problem- Help!
DuneRider
I have 1981 CJ7 , AMC 258 i6 / 4.2l , Renegade . I drove to the gas station and on the way it was overcharging. I pulled into the service station shut it off and pumped gas. I got back in and there was nothing! The key turned but no power. No head lights, dash lights, tail lights, and no nothing. I towed it home and here is what checked.
I had the battery tested...ok had 535 amps, the alternator was also tested at the parts store. ...tested ok. I replaced the solenoid, still nothing, the ignition switch, nothing.. Looked for blown fuses, all ok, looked at fuse links, believe it or not some fool removed them and straight wired it. I have checked the grounds and ones i checked were the battery to the block, the fender to the block, and the rear had a ground from the body to the frame all looked and checked
good.
My problem is that there us 12V coming from the battery to the post on the solenoid and absoluely nothing from the other post or the top two pins on the top of the solidnoid whether the key is off or on.
If anyone has any ideas please share them! Thanks, i havent a clue what to do. Please help!
