Electrical problem, no spark.
Okay, I’m new to the site and hope I am asking this question in the right place and forum. I have a 1983 CJ7 that came from the Toledo factory installed with the AMC 4-cylinder engine. I know, those didn't show up until 1984, but what can I say? Even I was surprised when I picked up the Jeep in fall of 83 after returning from a tour of duty in Germany.
I've kept the Jeep virtually stock except for adding a Weber 2barrel Carb about 4 years ago. Its been running great. Good pickup, especially for a 4 cyl. A few weeks back, it was hard to start, finally caught although running rough. I turned it off and it remains dead. I replaced the ignition module as that was usually the culprit in the past. No go. I traced the system and all wiring is good. I did a nutter bypass a half dozen years ago and it's been running great. I have a lot of new spare parts so I started by replacing the coil, coil connector, solenoid (even though it turns over great) plugs, cap, rotor, and the pick up coil in the distributor. Bottom line, no spark at the plugs. I used one of your threatpds and checked the power to the ignition module and that is fine. I probed the coil connector with a test light (bulb, not LED) and the red wire is bright when in run and start. The green wire is very dim in Run, and I get no light on the green wire in start. Knowing the ignition modules are notorious for being bad out of the box, I installed a second new spare. Still no spark. I'm stumped. Suggestions?
