Engine Assembly Lube Advice during Rebuild
DBCJ
I've torn down my AMC 258 i6 / 4.2l to just about nothing. Although for about the same cost, I could of swapped out to a new chevy motor, I wanted to keep it Jeep. Plus, its been a good father/son rebuild project. Here is what i have done so far:
Block and head have been hot dipped/cleaned
Cylinders bored .030
Valves/seats machined
Full master rebuild kit including:
-cam
-double roller timing set up
-New Pistions
Every single part on this engine has been cleaned and/or repainted!
We are just about ready to put it all back together, and Im trying to get some input on assembly lubes,ect. Ive been told to use assembly lube on some parts, and engine oil on others. What do you guys recommend for assembly lube for the following:
Camshaft bearings
Crankshaft bearings
Connecting rod bearings
Lifters
valves
Cylinder walls when reinstalling the pistons
Any other parts I should be lubing up as putting back together? If so, lube with what?
This has been our first full rebuild and it has been a great (and expensive) experience, but worth every penny, cut, scrape and bruise along the way!
-cam
-New Pistions
Camshaft bearings
Crankshaft bearings
Lifters
valves
