Engine sound change in the DD
WHATROAD
- Media
- 18
- Colorado Springs
- 1984 cj7 RENEGADE, Hard Top, factory air, reman 304 v8, ax15, D 300, D 30, AMC 20 with one piece axle, welded tubes and a searchers truss system, 4.56 gears, 4" lift, BFG 33x12.5x15, DirtWorx front and rear bumpers, rock sliders
Okay, maybe it's just too many years of listening to loud engine output. Maybe I suddenly lost a range of hearing that I use to have. Maybe not! We finally had a cold snap and the heater is on full in the soft top of choice. This morning, on the way to work at 6, I thought the jeep sounded muffled. As if the muffler had become better. I know, right!? Didn't think about it and trudged into work. Bound for home and again the engine sounds are muted. it just doesn't have the jeep AMC 258 i6 / 4.2l CID sound I know so well. No vacuum hiss, no loud compression on down shift, no water leaking from the water pump, no changes in power that I can tell, Weird! Beat down tired and not needing to drive tomorrow I'm just not ready to tear into it for a solution I'm baffled to come up with. Also not hoping to find that something of major bad
has crept into my life. Hoping on hearing loss I'll take all the input on this you folks want to give. Water Pump? Thanks in advance!
