Engine swap donor vehicle question?
GTOgoat
Northern Virginia
1985 CJ7, 258 i6, t176 trans, d20 with yukon one price axle and arb locker, d300 trans case, 4in yj conversion lift, 33in tires, 1ton drag link/tie rod.
Hello all, I'm thinking of doing an engine swap to an AMC 360 which I hear is an easy swap but need a few parts and this is where my question comes in. Would I be better off buying a donor vehicle such as a Grand Wagoneer with a 360 where I would have engine mounts, radiator and buy flywheel or get a 360 and buy mounts, radiator, flywheel? In general, what all can be used from the Grand Wagoneer? Other than having a spare set of axles to rebuild and use later is there any benefit?
