Factory Steering Stabilizer on a '77?..and leaf spring question.
65reissue
Alpena, AR
77 Jeep CJ5 - Renegade - 304 w/3 spd - pretty stock at the moment.
Hey guys...can you tell me if there was a factory steering stabilizer option on '77 CJ's?...and if so does anyone have pictures showing what they look like? I thought mine had one but ordered a replacement shock...the one I got has threads on one side and an eye on the other. When I started to change it I noticed that the current stabilizer is threaded on both ends. So...starting to think now this is an aftermarket stabilizer kit? Also...since I have you...I just got a 2.5" RC lift kit. Can someone tell me how I know which way/direction the front springs go? In other words the big eye or little eye go to the front? I thought I could tell by looking at the springs I took off...found instead that they had the rear springs up front...so not going to bank on that being correct. thanks for your help.
I had a 76 and that one had a stock stabilizer on it. And when I got the 79 I drive now there was an after market stabilizer on there, but I also still had the brackets where the stock one was removed from.
:)The factory bracket looks like this............it goes on the drivers side between the spring pack and the housing and is clamped there by the U-bolts. The other end with the stud clamps to the tie rod with a right angle bracket that should have been supplied.
:D:D:D:D
Ok...thanks guys. From the looks of my brackets, I don't have a factory stabilizer. Looks like I need to send this stabilizer back and see if they have the one I need that fits my set up. thanks again...
