flex-a-lite VSC and control switch
alaskaviper
- Watertown, NY
- 83 CJ-7, 6 cyl. with Howell TBI kit, TF 727 transmission Dana 300 twin stick, 2.5" suspension, 1" body lift, currently under repairs,
99 TJ, 6 cyl., 4" suspension lift on 33s
So I got a flex-a-lite fan and VSC. Now I was going to wire a switch for always on, thermostat, and OFF. now the flax-a-lite diagram shows how to wire a switch for ont or the other or using to different switchs. But is it possible to use a single SPDP, on-off-on switch?
Here is the original wiring
Can I just wire the SPDP switch so 12V source goes to middle switch, pin 5 goes to top of switch for manual off, and pin 6 goes to bottom of switch for manual on?
