Flywheel Cover?
Flywheel Cover?
Jeeper42
Michigan
Late 86 CJ7 Stock with a Dana 44.
YJ tub.
Still building it.
Hey Guys,
Does anyone know where I can find a flywheel cover like the one that is not in this image?
It is for my 1986 CJ7 AMC 258 i6 / 4.2l
Thanks!
Until I get back to it to look for numbers all I can tell you is it's for a 5 speed M/T that came with it.
What numbers should I be looking for?
Thanks for the help!
Thanks for the help on the ID on the Transmission .
Now does anybody know what is that cover called and where to find it?
Thanks again
Thanks again
Novak part number K437 https://www.novak-adapt.com/catalog/adapters/engine_to_transmission/ax15_nv3550_to_amc.htm
Names
Clutch housing shield plate
Bellhousing cover plate
Flywheel cover plate
I'd imagine you can hop on eBay and get one from a 91 to early 2000s xj,yj, tj, or zj as the bolt pattern for the bellhousing is the same in all amc blocks
Engine to housing spacer, you'll also need the clutch housing lower cover
Im pretty sure I have the upper part at home.. Ill have to dig around for the bottom.. Actually I think mine is a 1 peice unit. The 2 peice was for the autos so you can get to the flex plate/tourque converter bolts.
All the 6 and 8 cylinders manuals had a 2 piece. The one piece came on the 4 cylinder with hydraulic clutch.
