Ford 5.0L swap? What's involved?
raser13
- festus,MO
- 1977 CJ-5 '83 amc 258 straight six, motorcraft 2100 carb ,inline fuel pump, 1000 cca battery ,T-175 tranny,
OK boys and girls, time to get serious about my jeep's. I've been trying to keep my CJ5 pretty much stock or at least AMC. Mostly because I also like to restore AMC cars.and I like to keep them "in the family". But my jeep is starting to loose that battle. My classics will stay AMC. But I'm really beginning to start to look for alternatives.
I know that a Ford T-5 bell housing will bolt right up to my T-176 . So that part is bolt on. And that the splines will match up to the clutch. But what about the pilot bearing? Is there a conversion kit for bolt on motor mount points? Or do I have to weld them on? I'd like to make this reversible if at all possible.
I'd love to jump up to fuel injection. Any major wiring concerns there? I have no problems doing a rewire on this whole jeep. The harness has been raped hard several times in it's life and needs replacing anyhow. Just need to make sure I grab everything needed from the donor the first time. And anti theft is the other thing I'm worried about.
I'm just getting tired of waiting weeks for parts that I know others can just walk in and buy. All because I'm sporting an AMC motor. One broke part and I'm off the trail. Any other motor and I might be able to run to a parts house.
I'm looking at the Ford motor because the Transmission is a simple, bolt up procedure. It's small and compact for better fitment. And the five had a Chevy 350 originally in it. Kept breaking and bending distributors. Kept hitting the fire wall. Even after "adjusting" the wall with a hammer as far as I could with the vent system on the other side. Had no room to work with. They had the fuel line strapped to the exhaust for crying out loud!
So the ford conversion looks easier, and more bolt on. But I'm open to suggestions. So make your case if you think there is a better idea. Remember budget, and novice fab skills. Or point me towards a goid walkthrough. I tried the search. No luck.
So hook me up and let me know the pitfalls, and pros and con's.
