    To dismiss this notice
    click the top right X.
Fresh Air Intake Box
derekcj5
Bridgeport, TX
1977 CJ5 AMC304 T150 Dana 30/Aussie Locker Model 20/Trac Lock
1941 Willy's MB
Guys, I desperately need a pic of under the dash at someones freash air intake box. gotta hole in mine where i believe the drain is supposed to be. i'm going to glass me one up with a piece of pipe to drain it out into the engine bay. Any help would be appreciated...:chug:
I shall try to remember to take pictures tonight have them for you in the am.:cool:
unless someone wants to beat me to it.:D
What do you need a pic of the box or where the hose goes?
So pic's I pulled for jeepforum.
That large elongated hole at the bottom of the firewall, where you have a wire loom passing through, should have a steel plate screwed to it to seal it. The hole is for the optional air conditioning evaporator hoses to pass through. A flat steel plate is used to cover it and is usually sealed into place with body sealant.
beautiful... thanks man been tryin to see that view of one of them for awhile
$40.00
  20.0%
