Have a 84 CJ7 . Is there a trick with removing the front brake hoses? I removed the end at the caliper, but the other end I can't seem to get it off. I don't want to use any more pressure with the wrench and round the ends of the nut.
1977 CJ 7; Amc 401 .30 over, Howell TBI, modified Dana 20 with Terra Low gears and twin sticks, NV 4500 5-speed, modified Dana 30 and Amc 20 both with 4.56 gears (narrow track), ARB air lockers front and rear, SSBC rear disc brake conversion, MICO Brake park brake, Navaho brake booster/ master cylinder, PowerTank CO2 tank.
Use lots of PB Blaster on it and keep working the fitting back and forth. That's what I did on mine. Ended up with vise grips on one side to get it off.
