Front end shimy
cntymnty
- San Diego
- 1977 CJ5, rebuilt and balanced 258 w/fuel injection, high performance distributor, Clifford intake, header, T18 trans, Dana front, AMC rear w/one piece axle, mechanical lockers front/rear, 3.73's. BF Goodrich 33 x 10.50s.
My 1977 CJ5 has front end shake over 55 mph.. The only thing I have not done is replace the original tie rod ends. Would worn tie rod ends cause the shaking? I've replaced the shocks, steering stabilizer, balanced and tried rotating the tires. (the tires Bridgestone Desert Duelers, almost 30 years old but only have about 20K on them). Front bearings are good and recently serviced, I'
ve tried different air pressure, drive shafts are new and balanced. Any ideas?
