Steering Front End "Wobble" Issue. Opinions/ Ideas.
jafo
Old Time Jeeper
I have a '79 CJ7 . I have had a long going issue with the front wheels going into a wobble at around 50mph. It can be hit and miss depending on the quality of pavement. Sometimes it's the speed, sometimes a bump gets it started. You can accelerate through it and at around 60 mph it subsides or if you decelerate it will subside. I have upgraded or replaced almost every front end part. Borgeson steering shaft. Rugged Ridge heavy duty drag link and tie rod with the flip kit. New steering gear. M.O.R.E. steering gear bracket. M.O.R.E. 1/2" lift shackles. Moog ball joints, wheel bearings and races and seals. Spindle seals etc. New rotors, pads and calipers. Jeep has a 4" lift with the drop pitman arm. I installed 6 deg steel shims for positive caster. I just put it on an alignment rack to find out exactly where the caster angle was at. It sets at positive 5 deg. It actually helped getting the alignment. But it still has the shake. So I was going one of two routes. One is going with 8 deg shims. The other was going back to 0" lift shackles. Or both. But I am trying to get as much positive caster as possible without causing driveline angle issues. So what are some opinions or something maybe I have over looked?
