Front hub help
X2 on what 'Hack' sayz.....
MM hubs are the best. I run a D/L in the front, and they have held up very well.
I also use studs and ny-loc nuts on my hubs, instead of bolts.
So, on the studs thing... can someone tell me more about that? Pretend I am an idiot. Seriously. I do not understand the concept.
Thanks in advance!
Rather than running bolts, flat washers, and lock washers thru the hub to secure it, you run similarly long threaded studs (think 1 1/4" pieces of threaded rod) into the wheel hub, throw the locking hub onto the studies, a then use locking nuts on the studs to secure. It looks as though the bolts have been inserted from the back side.
Oh - WELCOME ABOARD!!!
Fantastic! Thank you very much! I have also heard there is some 5 to 6 stud conversion. Do you about that?
Truly appreciate it!
Yup - did that on mine. If I remember correctly, CJ's had 6 bolt hubs until they went to wide track axles, they had 5 bolt hubs. My CJ already had the wide tracks swapped over when I got it, and I had an old narrow track axle, so I swapped the hubs. Pretty much a straight swap. I wanted the premium Warn locking hubs and they only came in a 6 bolt pattern, that's why I swapped em over.
It's a piece of cake.
Another question - sorry to be a pest. So, remove a bolt, and get a stud of equal length (x10) along with appropriate washers/lock washers/nuts. Then, remove the hub, install the studs, and voila?
really that simple?
MileMarker hubs with Grade8 locking fastners:
https://milemarker.com/?make=11740&model=11741&year_id=11837&post_type=product&action=vpf-search
https://store.stage8.com/p/8901-warn-hub-bolt-kit?pp=24
I would advise against converting to a rear axle hub system. They are weaker than stock. Disconnect the rear driveshaft instead.
