Front leaf spring alignment
billyballer
- Media
- 3
- Oakland, CA
- 1986 CJ7: Renix 4.0 swap.
1969 MGB GT
1974 Capri race car
1970 Lotus Elan
1959 Lambretta
I recently installed 2.5" lift OME YJ springs on my CJ7 . I was running 2.5" lift springs before too, but they were old and super stiff. I also swapped in a newly built Dana 30 to replace my old stock Dana 30 . So the changes were new axle and new springs. So now I"m battling some serious handling issues. Hard to describe, but the jeep feels very nervous on the highway now. The overall height has not changed at all compared to the previous springs, and I'm running the same height shackles (a little over .5" lift). One thing I did notice is when I installed the front springs I attached the rear of the spring first, then attached it to the axle with u bolts, then attached the front shackles. When just the rear was attached and it was bolted up to the axle, the front of the springs did not line up perfectly with the frame. the both were about .5-1" offset to the outside of the shackle/frame, so I really had to tug them over.
I'm not really sure what would cause this. Maybe an issue with the axle itself? I guess I really want to know if this is contributing to my handling issues.
I have done a floor alignment at my shop and set the toe at about 1/16th in. I didn't add castor shims because I didn't change shackle height so didn't see the need because it handled well before.
At this point I'm just taking stabs in the dark. I suppose it's possible that the softer OME springs require better shocks and I need to step those up.
Open to suggestions and I'll try to grab some pictures of the springs.
