Front Leaf Spring U-Joint Install Question...
mdeluca
Full Time Jeeper
Hickory, NC
1986 CJ7, 258, T5, D30, D44, D300
Hey guys... quick question.
I'm installing a set of new leaf spring u-bolts in front. Do I put it on jack stands (frame) or leave it on the ground?
If stands, do I lift both sides or one side at a time?
Thanks.
Put the frame on jack stands (both sides) and use a jack to take the weight off the axle. Do one side at a time. Make sure you sort the one u-bolt that is different from the others. It goes on the passenger side.
