    To dismiss this notice
    click the top right X.
FST Performance FloMax300 & RPM350 Fuel Filter Systems
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
Filter Solutions Technologies / FST Performance announces the release of the FloMax300 & RPM350 performance fuel filter systems.
The RPM300 is a compact, high flow/low restriction system that filters down to 4 microns, much better than just a sock in the fuel tank as most Jeeps have.
• Compact: 4 ¼ inches tall X 3 inches wide X 3 ¾ inches deep
• Weight: 19 oz
• Flow: 300 gallons per hour (good to 2,000 HP)
• Filtering: 4 Microns (gasoline-methanol-ethanol compatible!)
• Filter media surface: 183 sq in
• Burst: 250psi (ideal for fuel injection or carburetor)
• Ports: ½ inch NPT pipe thread so that brass fittings can be used to splice into your existing fuel line.
• Water Separation: Not water blocking! Actually has a “quiet” zone for water and heavy contaminants to settle.
• Replacement spin-on type filter (RF500) for ease of changing. Nothing to service or clean out, eliminating the chance for fuel system contamination.
The RPM350 is a compact, high flow/low restriction system that filters down to 4 microns, unheard of in the performance industry.
• Compact: 4 ¾ inches tall X 3 inches wide X 3 ¾ inches deep
• Weight: 24 oz
• Ports: -8 A/N (ORB) but comes with -8 to -6 reducers if needed
Ideal for off-road and/or Jeep applications, the billet aluminum base is anodized red for a clean, custom look. Made & assembled in the U.S.A.
More info at www.fstperformance.com
FST Performance FloMax300 & RPM350 Fuel Filter Systems | Digg It | Add to del.icio.us
More...
